Re: Hole in my manifold.
Posted by Bama Binder on September 07, 2001 at 10:05:36 from (206.5.110.200):
In Reply to: Hole in my manifold. posted by Jeff on September 07, 2001 at 09:09:54:
I disagree with Marvin on this one. JB Weld is marvelous stuff, but I don't think it is a reasonable patch material. I think the heat limit is 600 degrees or so. I can't remember the exhaust gas temp, but I think it is at or above that level. I would start by trying to find a good one out of a salvage yard (may be just this side of impossible). A nickle sized hole may be reparable if the metal has good thickness to weld or braze to. My suggestion is to take the manifold off, have it sandblasted and/or hot tanked to remove rust and corrosion and then take it to a good welder and see if they can weld a patch over it (actually you probably need to have them look at it first to determine if it can be patched). Keep in mind that while this is your only hole now, there may be other areas where the metal is weak and thin, so you may have to do this again later. Keep in mind also that the design of the manifold is to heat the air/fuel mixture to a point higher than optimum for gas so the kerosene would vaporize better, so even though the manifold is a neat thing to have, it isn't the best for pure gas. Just my thoughts...BB
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
