Re: My '45 A Sounds Like a John Deere.....
Posted by Phil Auten (Tx) on September 15, 2001 at 10:50:58 from (63.173.243.86):
In Reply to: My '45 A Sounds Like a John Deere..... posted by ThatOtherGuy on September 14, 2001 at 18:28:40:
TOG, Do a compression check to see if the problem is the compression in one or more cylinders. Remove the plug wires one at a time to see which cylinders aren't firing or aren't firing correctly. Like Red said, swap plug wires to see if they are the problem. Replace the cap and rotor on the mag. Replace all the plugs with at least two heat ranges hotter plugs. Check to see if one or more valves are sticking or for bent pushrods. Check and reset the valve clearances. Finally, if none of these things help, pull the head and have a machine shop check it for cracks, especially in the combustion chamber areas. If overheated, these engines are subject to that type of failure, BTDT. Good luck, Phil
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
