Re: IHC 400 project
Posted by MN Charlie on November 22, 2001 at 07:30:13 from (216.188.194.32):
In Reply to: IHC 400 project posted by donwisc on November 21, 2001 at 18:12:19:
The Farmall 400 was sure a powerhouse if she has compession, spark and fuel. From my years of experience working in a IH shop don't forget about the air cleaner. A tractor with a mounted corn picker is always a very dirty, dusty machine to be around and guess where the engine is trying to get it's air from? Make sure you look very close at the wire mesh that does the filtering of the air in that oil bath air cleaner. I have taken those units off the tractor and very carefully disassembled completely. You have to cut some spot welds that hold the mesh in the bottom. Then pull the mesh out and unroll the many feet of wire mesh. A pressure washer will then do a good job of cleaning all of the goop out of the mesh. You can then roll it back up on a piece of pipe and install back into the air cleaner housing. If you just take the pressure washer to the wire mesh when it's still in the housing all you will do is drive the junk deeper into the wire mesh. If you know somebody that has a dynometer you can do lots of testing in just a few minutes. While under load remove the pipe from the air cleaner to the carb. Checking the power like this sure makes it easy to see results very quickly. You would be running an engine without the air cleaner only for a few minutes. I sure that many of these old tractors have air cleaners that will not allow engines to breath properly, especially those that had mounted corn pickers on them many years ago. Good luck Charlie in MN
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
