Re: High low battery charge settings for a '47 Farmall H
Posted by steve on January 18, 2002 at 19:10:38 from (204.246.222.134):
In Reply to: High low battery charge settings for a '47 Farmall H posted by atw on January 18, 2002 at 09:41:05:
a newer 12 volt system uses a votage regulator because it has a high current output. the older 6 volt systems had lower output current generators. some only put out 10 amps maximum. there were two differnt types of "regulators" for the 6 volt syste. the most basic is the "voltage cutout" which is a small box mounted normally on the generator. the G terminal on the generator gos to the G or a terminal on the cutout, and the other cutout terminal goes to the battery. the F terminal on the generator goes to the light swithc. there is a resistor in the light switch which acts as the "other half of a voltage regulator". the generator puts out 2-3 amps during the day with the light switch off (resistor in the circuit). when you pull out the switch the F terminal is connected straight to ground and the generator runs full out (about 8-10 amps) this works with the lights on. the cutout relay on the generator is adjusting the "voltage" to 6-7 volts at all times. the second type of "regulator" is an actual voltage-current regulator. it looks like what was used on cars in the early 1960 era. a black box about 3 inches square with three terminals on it (maybe 4). in this setup the resistor which was in the light switch is now in the "regulator" and works automatically to varry the chargning rate. you dont need to turn the light switch on or off. both the G and F terminals on the generator go to the regulator in this setup. the third terminal is B and goes to the battery.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
