Re: Farmall H Applied Physics
Posted by hugh MacKay on February 21, 2007 at 17:26:54 from (209.226.106.177):
In Reply to: Farmall H Applied Physics posted by City-Boy McCoy on February 21, 2007 at 15:44:38:
Mike: Three items that lower that center of graviety; wheel tread, solid wheel weights and liquid weight. You set that H on 72" rear wheel centers and it will be more stable than a utility at 64". I personally would never run a row crop at less than 72" centers. Then add the weight, liquid weight of course is the bast as it's closer to the ground. Wheel weights are good, just a bit harder to get as much weight. I realize today a lot of folks don't require or want all that weight, all the time. Here would be my approach, buy suit case weights as used on 06, 56, etc tractors. Since your going to dish the wheels out and go with 72" centers, fabricate two racks to clamp on front side of each axle carier. Fabricate them in such a way the entire suitcase weight is below top level of axle caries and wide enough to hold 6-100# weights on each axle carrier. Quick to put on and take off, being ahead of axle they will give a wee bit of front end weight. If you fabricate in such a way, top of weights are level with top of axle carier, that weight will be lower than wheel weights. I am starting to build these for my 140. I plan on using them for plowing and disking, then I can drop them while doing row crop cultivation. I'm only building mine for 4 weight on each side, and my main concern is traction. I really don't want to bother with chloride, very likely you don't either. If I were going full out bread and butter farming, yes I'd say go chloride for smaller tractors at least.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
