Re: farmall c
Posted by redblood on March 19, 2009 at 13:54:39 from (205.188.116.19):
In Reply to: farmall c posted by d farms on March 19, 2009 at 12:36:12:
I just got done setting mine. When you push the governor output arm backwards it may fall into a loose spot. I pushed the carb wot (backwards) and the governer arm to the point that the slop was gone but not preloading the spring (zero) and it works very well. Also high rpm may be off. Adjustable with the screw on top. Screw it out to set rpm higher. You need to have a way of measuring rpm, Ie tach.
Joe
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
