Re: ud 9 or wd9 gen belt removal
Posted by Ron in Nebr on March 05, 2007 at 18:48:51 from (66.252.115.84):
In Reply to: ud 9 or wd9 gen belt removal posted by Mike in shendoah valley on March 05, 2007 at 12:59:29:
You mean it won't fit over the fan, between the fan and the shroud, or do ya mean once it's almost on it's too short to fit on the pulleys?
Since you've done your MD, I assume you know how the fan pulley works(loosen set screw and unscrew the outer half of the pulley...being CAREFUL not to tap on it too hard cause they WILL crack).
If it's between the blades and the shroud, probably just one of those deals ya have to fight until you get it in "just the right spot" to work.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
