Re: Farmall A Series Cylinder Compression Ratings
Posted by dunniteowl on April 23, 2007 at 20:12:48 from (207.69.137.22):
In Reply to: Re: Farmall A Series Cylinder Compression Ratings posted by Janicholson on April 23, 2007 at 17:47:10:
Great advice, Janicholson! I will keep updating this as I go along. This comes from an original post called: Help Need the (Farmall) A Team! Where I reported that I had an overheat issue, found a blown head gasket, then couldn't get the compression done well, found I didn't install gasket correctly (no sealing compound-- oops!) and then couldn't seem to get compression in the cylinders to match too well. I ended up starting all over with the gasket (removed it, scraped off compound, lightly sanded head and block surfaces, reinstalled and re-torqued in 5 pound increments from 10 pounds up to the new standard of 80 with the new gaskets.) During that time there were a few times I tried to check compression without the rocker arm assembly installed. I know, stupid thing to do, but ultimately, I figured it couldn't really hurt as the pistons don't go to the top of the cylinder sleeve and the valves don't depress anywhere near the top of the cylinder wall/sleeve. Also I realize the cam-shaft is mated to the crank from below and not having the rocker arm assembly in place on top should not have any net negative effect. I am sure this could be wrong, but it logically seems sound from the perspective of construction. I do believe, however, that this could seriously affect the timing and again admit I am happy to be wrong about that. I am going to try the gas in the cylinder trick and if that doesn't do it, I will indeed be making sure the timing is set the way you suggest. From there I am sure new information will be coming. Once again, thanks for the tips and I will be posting new stuff as soon as I have daylight, dry ground and no other distractions (I have no garage or actual workspace for my tractor and I just have to 'rough' it where she currently is in the yard -- which is growing ever higher as I attempt to satisfy the conditions that will get her to operate again.)
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
