Re: Ask Your Friendly Ammeter
Posted by chadd on April 30, 2007 at 16:28:58 from (155.92.32.116):
In Reply to: Ask Your Friendly Ammeter posted by A. Bohemian on April 30, 2007 at 15:00:17:
I am not sure if anyone else has experienced this, but the needle on our Farmall M with a Delco distributor does not deflect whatsoever even when everything is set correctly. When troubleshooting a while ago, I decided to see if there was an ignition problem. I turned the ignition on with my dad on the seat and rotated the distributor as far as was possible. He said that it never once moved the ammeter needle. I figured that meant there was a problem, so I replaced the points, condenser, checked the advance springs, cleaned the connections, replaced the cap, rotor, and wires. I attempted the same procedure again to re-time the distributor, and my dad was right, again there was no deflection on the needle. I hit the starter, and the engine fired to life and ran really poorly, as the timing was off. I turned the distributor body until I got it running perfectly and then shut it down. Did the test again, and still no deflection. It deflects when the lights are turned on, and deflects varying amounts depending on the setting of the lights. It also shows charge when the tractor is started. Maybe the ignition system is getting its power from the battery and not going through the ammeter? I am pretty sure it gets power from in the light box though. . .
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
