Re: How do I get this thing to run??
Posted by brent thompson on April 03, 2002 at 04:31:53 from (216.144.16.81):
In Reply to: How do I get this thing to run?? posted by Don(PA) on April 02, 2002 at 19:01:22:
I have a couple items to try. 1. take carb off put your hand on manifold body where carbs goes - crank it over. do you feel a vacumm. yes, go to step 2. re-install carb. 3. remove plugs, and remove valve cover, HAND crank until #1 cylinder intake valve opens and closes - continue to hand crank until #1 is top dead center, now check you distrubter timing. is your rotor on #1 plug wire? if not adjust so it is.4. install wire on number #3 plug and turn it over until it sparks. - it should be only a 1/4 turn of the flywheel. Spark? yes. 5. shoot a little gas into each cylinder and re-install plugs, wires, etc.. It should fire up if everything else is correct. If your carb drips gas then adjust your float, by bending it down so that when it is all the way up it is level and not at an upward swing. If you have a backfire it sounds as if you may be 180 degress off time. easy to do. but if you follow my directions it wont be. If you think its 180 off. then try this before you do anything else try putting plug wires - 1 on 4, 3 on 2, 4 on 1, 2 on 3. this will put your timing 180 advanced.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
