Re: M clutch issues...again
Posted by ScottyNY on May 17, 2002 at 08:29:06 from (128.59.123.240):
In Reply to: M clutch issues...again posted by Dave from MN on May 17, 2002 at 08:16:58:
Dave, I just helped someone with the same problem. I'm assuming you having no luck in adjusting the free throw correctly, because you can't get any resistance from the clutch. If that's the case, the place to look is at the clutch cover and pressure plate. I shudder to suggest it, but you'll probably have to go back up inside and drop the whole rig again. Either the pressure plate is set too far ahead of the cover (meaning you can push on the opedal and get resistance but the clutch doesn't disengage),or (more likely and easier to adjust) the fingers are set too far forward, so that the throwout bearing never reaches them. If the former, you'll need to adjust the pressure plate clearance and then the fingers. If the latter, just the fingers. I'm at the office (read "no manuals here"), but will check in tonight. If no one else has come up with the correct settings for you, I'll look them up. What year is your M? Apologies for the long windedness. Scotty
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
