Re: How do I tell what bearings are bad?
Posted by ScottyNY on July 22, 2002 at 16:04:40 from (151.202.185.143):
In Reply to: How do I tell what bearings are bad? posted by richard on July 22, 2002 at 11:06:44:
Analyze your problem carefully there, Richard. If you do indeed have a bad bearing, it can be hard to pinpoint just by sound. Cast steel and iron carry sound real well. What you hear coming from your transmission could be comingup from the final drive. Try raising one wheel at a time and doing a little spinning and jiggling to see if that helps locate any problem. AS for difficulty, I just finished replacing everything fromt he differential bearings out on both sides of my BN. The lower bearings are pretty easy--just remember to put the long spacer back over the shaft before you seat the inner bearing. The upper bearings area little tougher and will require a hoist other assistance to help pull, particularly on the right side of your A. Those bearings don't reauire you to split the tractor. As important as any help is making sure you have your tractor is well-chocked and supported SECURELY. Even doing one side at a time, with the right side shaft, housing and final off an A, you have something pretty heavy and pretty narrow hanging up in the air. If you should bang that heavy right wheel getting it back on, you don't want anything that's going to move very far at all. More than 2 cents, I know.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
