Re: how can i get more power out of my 1943 m
Posted by Phil Auten (Tx) on July 31, 2002 at 09:52:26 from (63.173.243.93):
In Reply to: how can i get more power out of my 1943 m posted by emmett on July 30, 2002 at 18:35:40:
The 4" sleeves by themselves will only yield about 4 HP. The Super M had slightly higher compression than the M to get the other 4 HP difference. If you can find one, get a LP head from a Super M to get the compression up further. Also, the Super M used aluminum pistons instead of cast iron and this may account for the difference in compression. With the aluminum pistons and LP head you should realize about 6.75:1 compression ratio instead of the standard 5.65:1 of the M. If you can't find or afford the LP head, have your head milled a little and use the Super M pistons. There are formulas for figuring out the change in compression ratios for different amounts of material removed in the milling process, but I can't find the book I have that lists them. Go lightly, about .010-.020" and see what happens. Remember that milling the head will alter the valvetrain geometry and your pushrods may have to be shortened to compensate for the change if you can't get the valves to adjust to spec after the change. Also, try to find a M&W governor weight kit or similar. This will retard the action of the governor and give higher max RPM. If you are pulling, check your club rules to be sure this won't disqualify you. Open up the main jet slightly after you get the tractor running and work up to the size that gives you best power. Good luck, Phil
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
