Re: IH model 240 hyrdaulics
Posted by Scott Price on January 18, 2003 at 11:15:04 from (64.22.197.87):
In Reply to: IH model 240 hyrdaulics posted by Joe Herold on January 18, 2003 at 05:07:31:
I also have a 240 Utility. If you have both an operator's manual, and a service manual there should be info in them with the answers. The hydraulic fill is a plug on the left side of the flat top of the center housing under the fuel tank. The drain is directly below the fill plug, along the left side at the bottom of the housing. The drain looks just like the other bolts along the bottom of the housing, but once you put a wrench on it you will know it is the drain plug. There is a suction screen in the system, that is located under the fuel tank on the right side. It is in the side of the large housing that the hydraulic pump lines run to. It has a square cover that is about two inches square and held on by four capscrews. Pull the cover off and clean the screen inside. If you pull the drain plug, and find that greenish milky fluid drains out first, you have alot of water in the hydraulic oil. This is not unusual on these older tractors, especially if the hydraulic oil has not been changed in a long time and they sit outside. If there is water, I recommend refilling with a cheap generic hydraulic oil and exercising all of the hydraulics many times before draining the fluid again. This will help get any moisture out of the lines and cylinders, and let it settle in the bottom of the hydraulic reservoir. Let it sit overnight to settle, and then drain again. Refill the second time with Hy-Tran or equivilant hydraulic oil and you should be in pretty good shape. You may also want to clean the suction screen again before the final fill, as the moisture tends to collect there also. If you have not already, you should do the same with the trans and rear end, as they also collect moisture over the years. Use a cheap lightweight trans fluid for the first fill, and after running and draining refill with a good gear lube in the 80-140W range, depending upon your climate. Where are you located?
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
