Re: 6v generator to 12v generator
Posted by steve on January 23, 2003 at 16:17:48 from (204.246.222.26):
In Reply to: 6v generator to 12v generator posted by JohnG(TX) on January 23, 2003 at 12:15:48:
a good 6 volt generator will put out about 15 volts when run wide open. you can ground the "F" terminal and start tractor, then measure the voltage across the "A" and "F" terminals. If it is above 12, you can then install a 12 volt regulator to "regulate" the voltage. You are right about the current draw. THe two main porblems you will run into are that 6 volt generators only put out about 8 amps (most of them) so you can use it to trickel charge a battery, but dont run a bunch of lights. second problem is you r 6 volt system is positive ground and when you boost the generator to 12 volt it will still be positive ground. Most new systems are negative ground. Only way to get around that is it install a different generator, or get it rewound. Best bet is to get a regulator at Auto Zone for a generic unit, like 1960 chevy pickup, should cost about $25. make sure it can be polarized positive or negative. then you are all set. leave the system positive ground.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
