Re: H lift-all noise
Posted by farmall man II on May 05, 2003 at 20:37:06 from (209.103.199.72):
In Reply to: H lift-all noise posted by John on May 05, 2003 at 19:09:35:
Make for sure you have oil in there first. then make sure all is tight and check the drive spline. make sure that the spline is all there and good and tight
Post A Followup
: Re: Re: H lift-all noise
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
