Re: Re: H lift-all noise
Posted by John on May 06, 2003 at 05:22:34 from (192.233.162.110):
In Reply to: Re: H lift-all noise posted by Gary-Miss on May 05, 2003 at 19:18:19:
Thanks Guys!!! My lift-all is tight, new 6 qt. of Hytran in it, the only thing I did was take that drive coupling off to replace the trans side seal. When I put the coupling back in, it is now a little loose. The lift-all doesn't make any noise when the tractor is running, only when I pulled the control rod (No cylinder attached).
Post A Followup
: Re: Re: Re: H lift-all noise
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
