Re: 1206 TA Adjustment
Posted by Aces on May 06, 2003 at 15:38:58 from (205.186.122.68):
In Reply to: 1206 TA Adjustment posted by jarrod on May 06, 2003 at 09:57:47:
If it is a farmall. first make sure main clutch has the right free play, about 3/4 inch from deck the little dump valve out the back of MCV should make contect with main clutch at this time just make sure that when main clutch is all the way down pump valve is all the way out but not tight. the TA valve should set on the snap ring when lever is forward and all the way up when in TA but tight in the link under the hood is a forward and back for lever. I would use the TA but when you shaft, shaft like you meen it that is why it has an over senter lever warm up thactor first if that meens making a round or 2 in lower gear in cold weather don't use it in TA.
Post A Followup
: Re: Re: 1206 TA Adjustment
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
