1944 Farmall A PTO Problem
Posted by LarryE on June 24, 2003 at 17:47:37 from (209.214.64.172):
This is all new to me. I'm not sure if I have a problem or if this is somewhat normal for the Farmall A, but when I engage the PTO it grinds so hard it stings my hand. This must be excessive. How do I fix this? Also, I've been told that some folks are putting STP in the transmisson to stop the tranny when the clutch is engageed so it's not spinning when you go to put it in gear. Is this a good idea? Mine grinds when I put it into gear the first two or three times. After that it seems okay. Does anything else operate off of the transmission? Appreciate the help.
Post A Followup
: Re: 1944 Farmall A PTO Problem
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
