Farmall Tractors Discussion Board
Re: M electrical system
Posted by Phil Auten on October 18, 1999 at 05:51:18 from (206.175.72.226):
In Reply to: M electrical system posted by McClary on October 17, 1999 at 18:37:59:
McClary,
If it has a battery in it, how many cells does the battery have? 3 cells = 6V and 6 cells = 12V. Otherwise, assume it's 6V and go from there, it'll be original that way. Since you're rewiring it anyway, just be sure all the connections are clean and bright before you tighten them down. Make sure that the battery cables are at least 2 Ga. wire (bigger is better on a 6V system). Also, clean the starter where it mounts to the bellhousing and the mounting hole in the bellhousing so the starter has a good ground.
Also, have the starter checked out (and the generator too) before you try to start it up to eliminate them from the problem list.
Have a ball!
Phil
Post a Followup
: Re: Re: M electrical system
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
