Help! 460 Hydraulic System Woes.
Posted by Joe Evans on March 18, 2004 at 15:05:35 from (209.41.235.201):
Finally addressed the forever lousy 460 hydraulic system performance today. Installed a rebuilt Cessna pump. I was very concerned about the pump's intake system. Despite installing a new pump and putting to rest questions about pump output, I felt for sure there would be a problem with cavitation due to old O-rings inside the transmission and such. Once I finally got the 460 to start (hasn't run since August) after installing the pump, it ran for about 5 seconds and then a horrible low-pitch squealing noise was heard. The 460 bogged down, and I immediately shut it off. My first thoughts were that the pump drive got destroyed, but looking down at the fast-hitch I noticed it had raised up fairly high. Well, apparently the pump picked up prime and was moving oil which was a quantum leap over the totally shot (and I do mean TOTALLY) old pump. It had been so long since the drawbar was able to be raised that high, I figured the lift cylinder had topped out and the pump was up against the relief valve causing the nasty noise. I then positioned the lever so that the hitch would be lowering when I started the 460 again. I started her again,and the hitch began moving downward with no noise until the cylinder bottomed out, making more noise with the tractor bogging down. I raised the hitch--no noise until topping out. Well, you get the picture. I have to continually cycle the hitch up and down to avoid the noise and bogging the tractor. There is no "neutral" or hold position--the hitch must be kept moving. If I try to "hold" at a certain height, the noise returns. The noise sounds like a relief valve blowing off although it is a much lower note than other high-pitched reliefs I've been around. It's like a very fast--frequency chatter. The 460's system never was 'right' all the time Dad had it. Most of the complaints were water in the system and lack of holding position. It's been eons since the 460's system has seen the pressures the newly installed pump seems to be delivering. Sorry for the long ramble. Any suggestions?
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
