Re: Re: Re: Do I need to adjust my valves on an H?
Posted by Ron in Nebr. on April 03, 2004 at 00:53:59 from (65.172.143.221):
In Reply to: Re: Re: Do I need to adjust my valves on an H? posted by CNKS on April 02, 2004 at 19:37:41:
Not wanting to start an argument here, but if the valves are at .015" hot and they're supposed to be at .018" hot, they're still closing fully. They'd still be closing fully if they only had .005" hot clearance. As long as there is clearance between the rocker arm and the valvestem when the cam is on the base circle, the valves are closed. The deal is, they won't be closed for quite as long of a time, and, more importantly in some cases, they will be opening farther. Some engines have very little clearance between the valve and the piston at full valve lift and it doesn't take much over specs to have them touch and bend the valve. Doubt the H's were that close, but it's still best to set them to specs(either right on for hot or add .002" for cold. A good way to set them "hot" and be able to have the temp right is to get everything taken off beforehand and just set the valvecover back on to contain the oil splash, then run the engine with a blanket over the radiator/grill shell so it can't get any air. It'll warm up plenty fast that way and you can get them set/checked before it cools enough to make a difference. Cast iron retains heat for a good amount of time.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
