Re: need a source for a tranny top gasket.........
Posted by Paul in Mich on April 30, 2004 at 19:55:51 from (68.188.227.110):
In Reply to: need a source for a tranny top gasket............. posted by 49 Cubber! on April 30, 2004 at 15:59:09:
Cubber, I buy very few paper gaskets, as I find it as easy to make my own as to make the trip to the Case IH dealer. If you buy sheet gasket material, it is easy to make one by placing the material over the surface you plan to gasket. Then if it has dowell pin locaters, you can peen around them to set the material flat. Then I keep several sizes of ball bearings handy and place them over the bolt holes and one by one tap the ball bearing till the hole forms in the gasket. I then place a bolt in that hole a couple threads deep to hold everything in place and go all around and repeat the process for each bolt hole. once the bolt hole pattern is complete, tap the outside perimeter, then the inside perimeter to establish the contour then remove the gasket and cut out the contour, and "voila", the gasket is ready to apply what ever "Oozy Smoozy" you use and install. This should work fine for your transmission cover. YOu will have a large slug of gasket material from the center, but useable for some other time when you need a piece that size or smaller. I get a lot of mileage out of a roll of gasket material as I throw very little away. I keep several thicknesses on hand.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
