Help for IH 1486 Hydraulics
Posted by Francisco Lopez on May 21, 2004 at 15:44:27 from (200.66.165.247):
I would be very grateful if I could get advice on the problems I´m experiencing. I must tell I got this tractor early this year and was parked for almost a year. I did work on the engine like injectors, pump, belts,change radiator changed clutch,shaft etc. 1.-Brakes were checked, discks all of them allright only change the "o"rings and bleed air. But air almost never got it out. The pedal is still soft. Where could I be getting this air from? 2.- Decided to use the tractor on a flat surface to plow.Tractor is able to raise and turn the implement.After half an hour of plowing it is very evident that the power to raise the implement is reduced because takes more time to do it. Also to turn the plow it gets almost impossible. I open a house to see if it wasn't clugged and noticed oil very thin (no very hot). Filter was chenged before operating it almost 1 month ago. I inspected the oil cooler and noticed there is no flow even with the tractor running. No flow from the multiple control valve. As you may know there are two pumps, one for the brakes and steering and the other for the 3 point and plow. I would be very grateful if any of you could provide advise. All suggestions are more than wellcome.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
