Posted by Mike Franks on April 03, 2009 at 19:35:35 from (208.72.144.106):
Today I removed the rear axle assembly out of my cub tractor to replace the bearings and seals in the final drive. I am really having a problem removing the shaft that goes thru the bull gear. The IT manual says to bump the shaft. I have tried everything except the press to try to remove it. I didn't want to try the press for fear of breaking the gear or something else. Any help would be appreciated. Thanks
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
