Posted by banjo on April 03, 2009 at 21:18:28 from (65.67.203.13):
In Reply to: 1948 Cub final drive. posted by Mike Franks on April 03, 2009 at 19:35:35:
the bearings are pressed on.they can be pretty tight. make sure you have all the bolts out of both sides. once you get the shaft off the inside bearing it should come on out. But you will still have to pull the outer bearing once the shaft is out.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
