Anything you use to seal will change the play, albeit only slightly. Silicone is the worst offender. Clean the shims real good and make sure they are flat. I use a sanding block with 180 emory cloth followed by Scothbrite and then a light dusting of High Tack, never had a leaker. What is worse to try to seal is the area where the belt pulley is attached to the splined shaft. 80% of the spacer length is over the splined area with only a small remaining contact area where the splines end. It's a poor design. Clean with brake cleaner and use a small amount of black RTV when you install the spacer.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
