Posted by JimB2 on April 05, 2009 at 07:28:51 from (99.240.236.11):
In Reply to: IH 674/684 posted by clampit on April 04, 2009 at 22:45:07:
Hi, the only area that is different between 674/684 is the spacing of the mounting holes on the casting in front of the rad. We attempted to put a front cast weight from 674 on 684 and holes would not line up. Some loaders only use the sde mounting holes which are the same. We moved a 2250 from 495 to 3230 and we had to drill two new holes in front mounting plate.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
