Re: Loader question on 656.. possible purchase
Posted by Weldon on June 27, 2005 at 15:17:36 from (151.213.96.203):
In Reply to: Loader question on 656.. possible purchase posted by Darren McLaughlin on June 26, 2005 at 14:57:08:
Darren, Some things come to mind in regards to your wanting to mount a 2000 loader on your 656. First , is your tractor the International (utility style ) or the Farmall (row crop style )? There is a big difference in the front mounting brackets used on the International as compared to the Farmall.You will need to have the proper brackets. Second, What tractor had the loader previously been mounted on? There is a difference in the rear axle attachment of the loader sub-frame for various models . You mention U-bolts not being with the loader. Large U-bolts are used when mounting on 706, 856, etc. These tractors have a hexagonal shaped rear axle housing and the rear of the sub-frame is made differently from a sub-frame that fits on a square rear axle housing as found on 656, 504 and others. Also the sub-frame for a loader on a 06, 56 series tractor is longer than what is used on a 656. It would require that the sub-frame be shortened by the proper amount and the correct axle mounting be fabricated if you are going to mount a loader from 06 , 56 series onto a 656. Third, Does your tractor have two auxiliary hydraulic valves? If so , no problem, use the tractor valves for operation of loader. If only one, then you will need to get a two spool loader control valve ( available from any hydraulics supplier) and run lines from your tractor outlets to the new two spool valve and use the two spool for the loader and bucket controls. Reply if you have any questions. Weldon
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
