Re: Throttle Body Injection for 50 Yr. Old Farmall
Posted by Janicholson on September 07, 2005 at 15:12:14 from (199.17.6.175):
In Reply to: Re: Throttle Body Injection for 50 Yr. Old Farmall posted by RustyFarmall on September 07, 2005 at 13:51:52:
Stop stop your both correct!!!!! The issue is getting a computer system to feed the stochiometric (ideal)14:1 air to fuel ratio to the engine under warm run conditions, variable loads, and speeds ranging from 450 to 2500 (for those with the wick turned up higher). Also needed is a method of providing cold start enrichment, and high vacuum shutoff. The best approach is to use a system that triggers off of a crank sensor (magnet can be placed on flywheel), oxygen sensor (drilled into exhaust manafold), and various temperature, pressure, and air flow transducers. I think it is entirely possible. Robbing a donor car, and making the system work correctly is not hard, just time consuming and worthit if the end result is good looking, functional/reliable. It should then be written up in a how to booklet so that others can follow by cook book implementation. Govenor action would be from existing linkage to the throttle body, or air flow control. Would it help? yes. We could even use a catylitic converter to advantage. For antiques and show purposes, no way. Our future with working tractors is to be responsible, conservative with resources, and to not throwaway good usable high reliability hardware. the prices of new tractors wounds my retinas. It is an item I hope to "supercharge" some of my better students into attempting in the next few years. JimN
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
