M 12 volt conversion starter motor issue
Posted by e-manhunt on November 14, 2005 at 15:16:25 from (66.166.69.50):
Just had the starter drive rebuilt --the gears were chewed off -- and I am thankful the problem wasn't a chewed up gear ring. However, the guy who fixed the starter said the gear teeth sheared off the starter because it was spinning too fast because of the 12 volt conversion. The starter couldn't engage all the way, so the gears were sheared off by the gear ring. He thought this would continue to happen. What do you think? I don't know if this makes sense.
Post a Followup
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
