Re: M Flooding
Posted by Janicholson on April 05, 2006 at 12:29:18 from (199.17.6.175):
In Reply to: M Flooding posted by ACRE on April 05, 2006 at 12:18:24:
With the gas shut off at the tank, remove the carb bowl. Hold the float up with one hand, and turn on the fuel at the tank. Letting the float drop, should provide fuel, holding it up gently should stop it. If it does stop it, shut off the fuel again and remove the float. (do not loose parts) Check to determine if the float has become filled with fuel (shake it). If full, it can be emptied (outside) by using a soldering (not with a torch)to heat the float. Gas will come out of the leak that let it in (be careful to not spark). When no more gas is inside, solder up the hole/crack. and reinstall the needle and float. If it did not stop the flow, there is either a need for a new needle/seat, or a piece of trash in the seat jambing the needle open. Clean it out! Good luck, JimN
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
