Re: Super C icing-up
Posted by captaink on April 07, 2006 at 14:05:05 from (66.115.214.56):
In Reply to: Super C icing-up posted by Trickster on April 07, 2006 at 13:34:43:
This is totally normal. It is caused by the venturi effect which is that when air passes through a space that is smaller in diameter (like the venturi of a carburetor), the air flow speeds up and absorbs heat from the surrounding surface. This removal of heat (or cooling) will condense moisture in the surrounding air on the cooler surface. If the temps are close enough to freezing, ice will form not only outside but also on the inside. This cooling affects the air/fuel mixture causing the engine to run rich until heat from the exhaust manifold overcomes the cooling venturi effect. Now, is this what is causing your engine to stop after 20 minutes or so? Well, it might as this condition can richen the fuel mixture enough to flood the engine bad enough to cause it to stall. If you are seeing black smoke from the exhaust before it dies, then this is likely the cause. The cure is to run the engine faster or somehow get heat to the area that is freezing up. Sometimes gas line antifreeze (or running ethanol) will absorb enough of the moisture inside the carburetor to cut down on this problem.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
