Re: Super C Was good!
Posted by El Toro on May 29, 2006 at 19:18:56 from (152.163.100.65):
In Reply to: Super C Was good! posted by Andrew Z on May 29, 2006 at 17:49:59:
Remove No1 sparkplug and bring that piston to TDC on the compression stroke. Hold your thumb over the plug hole while someone hand cranks the engine slowly until you feel pressure against your thumb. Then look for the timing mark on the flywheel while they slowly keep cranking. You can also drop a large handle screwdriver into the hole and watch the screwdriver until it quits rising. Your timing mark should be very close. It may be hard to see too. Once you have it aligned with indicator remove the distributor cap and see where the rotor is pointing. No1 plug is near the radiator. Your rotor should be at the No1 plug tower. If it's off the engine may have jumped time. Take a good look at the inside of the distributor cap for any cracks. Hal
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
