Re: Super C Was good!
Posted by Hugh MacKay on May 30, 2006 at 02:03:18 from (216.208.58.159):
In Reply to: Super C Was good! posted by Andrew Z on May 29, 2006 at 17:49:59:
Andrew: I have to go along with Hal's test check, you should do that anyhow before you remove the distributor. First I would check to see if rotor turns without engine turning. My first reaction was someone switched some spark plug wires on you but that didn't happen as you were driving home. My next suggestion and I had this happen once, there is a very small gear drive in housing just ahead of distributor. This transfers power from timing gears to the distributor. When mine went, it would get off a few degrees, act like your description, then quit. I turned it a bit on starter it did come right once, and started but smooth running was short lived. I removed the distributor cap and found I could turn the rotor quite freely, although it would catch in spots. The small gear was striped.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
