Re: Stuck
Posted by old on August 06, 2006 at 15:07:04 from (4.244.186.76):
In Reply to: Stuck posted by Henry E on August 06, 2006 at 14:50:54:
First thing I would do is blow out the PB in my book its not any good for that. Then I would fill the cylinders with tranny fluid and put the plugs back in. If just the tranny fluid doesn't work then in a couple weeks top that off with turpentine, not paint thinner but the true turpentine. If those don't work you will have to open it up and probably use a press or hammer to get them loose
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
