Re: Stuck
Posted by John A. on August 06, 2006 at 19:18:41 from (4.252.246.31):
In Reply to: Stuck posted by Henry E on August 06, 2006 at 14:50:54:
Henry, Dismaantale the engine as far as possible as possible, then tear down the underside too. Remove fuel tank and other combustables from the area. Roll outside.... pour the #1 cylinder full of DSL then just a splash of gas so it will ignite. Then set on fire, let it burn itself out. Then take a wood block and a 4lb sledge hammer and drive it down / or up to get it to break free. Then repeat the process on each of the other 3 pistons, one at a time. The fire will cause the cylinder to expand and the heat will help breakup the rust, and some of the DSL will help provide lube to get it moveing. if one attent doesn't get it done, ....do it again! Just be safe, keep all combustables away. make sure the flames do not set the barn on fire. This technique has always worked when done right. Good Luck, Later, John A.
Home
| Forums
Today's Featured Article -
Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
