Re: Tank Heater Placement On 806D
Posted by Hugh MacKay on September 09, 2006 at 01:41:02 from (216.208.58.184):
In Reply to: Re: Tank Heater Placement On 806D posted by Harlen Larson on September 08, 2006 at 20:59:22:
Harlen: I had a feeling block drain was on opposite side on 806. I was very lucky, my engines all had block drain directly below the port on the head. The circulating heaters I had were cylinder shaped, about 7-8" long and 3" in diameter. I found they worked best if you could position them upright so discharge was directly above the inlet. That free flow of hot coolant going up and return coming to the bottom of heater is quite important. I your case I'd be tempted to mount the heater just below the port on the head, then run the hose from the block drain under the engine. I'd be afraid of the hose on top of clutch housing lying too flat. Basically what your trying to do here is run a hot water heating system without a circulating pump. Techincally it's very similar to thermosyphon in the Super A. The better you can make flow, the more effective it will be.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
