Re: Farmall 100 transmission leaks????????????????
Posted by Haas on December 12, 2006 at 19:26:49 from (12.65.24.202):
In Reply to: Farmall 100 transmission leaks???????????????????? posted by Patrick Martin on December 12, 2006 at 10:08:30:
If you put more than 5 quarts in the transmission, it is over filled. Level plug is behind brake rod at front of transmission on left hand side. You have to take the pin out of the brake rod clevis to get to it. Those are not overfill ports. But as the others said, but are drain holes to let out any transmission oil that leaks past the differential shaft seal into the brake chamber. If oil gets on the brake linings, you will have very little in the way of brakes soon. Even if the differential shaft seals are in decent condition, if the transmission is overfilled, you are likely to get leakage. The seals are not too hard to replace, but you do have to remove the final drives housings to do it. That and the wheels, especially the right side cast hub are heavy. So be careful and if you decide to do it, do one side at a time, and block up securely. The tractor is not very stable due to the offset design, especially when the heavy cast wheel on the right side is removed. Removing the cast wheel hub takes away the counter balance.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
