Re: Farmall M Shifting Troubles
Posted by City-Boy McCoy on December 18, 2006 at 15:46:20 from (68.221.167.193):
In Reply to: Farmall M Shifting Troubles posted by MMRT on December 18, 2006 at 14:21:42:
If the tractor won't shift into gear from neutral while the engine is running, the clutch disc is probably stuck to the pressure plate or flywheel. Many times this can be broken loose by placing the tractor in 1st gear, pushing in and holding in the clutch, and then starting up the tractor - several times - with a good bit of throttle. Keep the clutch pedal depressed. Just be out in a big open area and allow yourself room to shut it off and stop rolling before you hit something. When it breaks loose, it will probably be fine from then on.... I mention this next consideration only because you said this is your very first tractor: If what you mean is you can not shift from one gear to another without violent grinding while the tractor is moving, that is normal as the gears in an M, like most tractors, are not synchronized. mike
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
