Re: Delco Alt. 1 wire to 3 wire
Posted by Bob on February 14, 2007 at 15:57:47 from (69.178.229.154):
In Reply to: Delco Alt. 1 wire to 3 wire posted by SuperA-Tx on February 14, 2007 at 15:44:24:
(This is "Bob", NOT BobM.) SOME so-called "one-wire" alternators will act like standard "3-wire" alternators if you add the extra wires that plug into the internal voltage regulator (who's pins MAY be covered by a rubber plug). With other "one-wire" alternators, this will not work. I know of NO way to determine this, looking at the alternor from the outside, as it has to do with the electronics inside the internal voltage regulator. You can always "swap out" the "one-wire" internal regulator for a (standard) 3-wire unit. Some "one-wire" units have an "oddball" diode setup, instead of the standard "diode trio" in a "3-wire" unit. This can be swapped, too. The 1N5408 diode shown in my photos works equally as well as the "idiot light" that can also be used. It's a matter of choice which way you want to go. A 10 Ohm 10Watt wirewound ceramic-case power resistor is another direct alternative to the light ot the diode. The 1N5408 diode is very robust, and yet is CHEAP. Some of the other guys around here seem to get by OK with lesser-rated diodes.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
