Re: Delco Alt. 1 wire to 3 wire
Posted by Jon Hagen on February 14, 2007 at 20:26:54 from (75.104.56.247):
In Reply to: Re: Delco Alt. 1 wire to 3 wire posted by Bob on February 14, 2007 at 15:57:47:
If you get an auto parts store replacement regulator plug($2), so you do not have a chance of shorting exposed regulator terminals to the alternator case, there is a 99% chance it will work with your existing regulator. I have not found one of Bob's one wire regulators that use an odd diode trio setup, but on the chance you have one,and it might not like having power supplied to the #1 regulator terminal, I would use the little idiot light inline in the #1 wire. That little light bulb will only allow a fraction of an amp to flow to the alternator regulator #1 terminal and has little chance of causing any damage if the "one wire" regulator is one of those oddballs Bob talks about. A diode will allow quite a few amps to flow untill either the diode or the oddball alternator component fails. Another couple of pluses for the bulb is that it can serve as a visual charge indicator and is avalible at most any hardware,store, auto parts store, farm store. I just installed a one wire alternator I had on the shelf on a project where we needed a working charge light, With the wiring connected as in Bob's drawing, it works exactly like a standard"three wire" alternator. It excites at idle and the charge light works as intended. The instruction sheet that came with my last box of "one wire" regulators said that if the alternators excite speed was too high or if the project needed a charge light, that it was OK to install the wiring as in a stock 3 wire system.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
