Re: Delco Alt. 1 wire to 3 wire
Posted by Bob M on February 15, 2007 at 06:51:06 from (151.190.254.108):
In Reply to: Re: Delco Alt. 1 wire to 3 wire posted by teddy52food on February 15, 2007 at 06:21:50:
It's pretty simple: 1 - Disconnect the ground cable from the battery (safety first!). Also loosen the alternator drive belt - this makes reassembly easier later on. 2 - Pull the aux wiring connector (2-terminal plug) from the back of the alternator. You can leave the heavy alternator output (BAT) cable connected. 3 - Remove 4 screws holding the alternator halves together. 4 - Gently separate and remove the rear cover from the alternator. The stator winding will come off with the rear cover. 5 - The regulator and brush holder assembly is screwed to the inside of the rear cover - and is now easily removed/replaced. Be sure to replace insulating washers, etc. in their original locations! Reverse the above steps to reassemble. ---- Tip: Before sliding the rear cover back onto the alternator push both brushes fully into the brush holder. Now take a piece of stiff wire (a straightened paper clip will work) and insert it thru the hole provided in the back cover, then thru the 2 rentention holes in the brush holder. This will hold the brushes out of the way while you reinstall the rear cover. Then after the rear cover is back in place, simply pull the wire out from the rear and the brushes will drop onto the slip rings.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
