Farmall H main drive housing removal
Posted by SLH IN MO on June 30, 2007 at 10:13:58 from (70.242.143.137):
Can anyone tell me can the main drive shaft housing bearing assembly be removed on a farmall h .without removing the transmission top or belt pully housing.THANKS for any help.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
