Re: 400 Whats the Fix???
Posted by City-Boy McCoy on July 09, 2007 at 04:01:07 from (68.221.170.122):
In Reply to: 400 Whats the Fix??? posted by Short Bolt on July 09, 2007 at 03:40:10:
Sounds like something is causing it to run excessively lean. Lean engines run hot; hot engines are prone to pre-ignition and will run on when you hit the kill switch. Look for a major air leak somewhere - probably the intake gasket, or even a crack in the intake manifold. Or perhaps you have a partially clogged carb. If the 92 year old farmer let the tractor sit for a while, you probably ought to go through the carb thoroughly - disassembly and a good soaking in a bucket of carb cleaner, then blow it out and check all passages, finally, reassembly with a quality carb kit. mike durhan
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
