Re: So I have this idea........
Posted by Owen Aaland on July 11, 2007 at 19:59:27 from (65.165.246.40):
In Reply to: So I have this idea........ posted by Patrick Martin on July 11, 2007 at 19:43:12:
It should work but there are some areas of concern. The first thing is you would be adding belts and pulleys in the area where the operater sits so you would have to make sure that you had proper shielding to prevent injuries. The PTO runs at about 1/3 of the RPM of the engine so you would need a pulley three times as big on the PTO as you would on the crankshaft. You only have hydraulics when the clutch and PTO is engaged. It might work fine for your application but may not be so handy when you find something else you want to use with hydraulics. Something else to think about,your engine block should be able to accept a hydraulic pump so if you could find a pump and gear you could still fabricate your own reservoir and plumbing and have a much more user friendly system.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
