I went to my steel supplier and they said it would be no problem to cut a piece with a CNC plasma cutter. They have an automatated set-up that grabs the steel, places it on the table and then cuts it to dimension. I believe they called the steel A-14. Said the farmers use it to rebuild plows, etc. I am not sure how or if I could drill it. I suppose a cobalt drill bit, some cooling oil and a drill press would work?? Thanks, Terry
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
