peabody george is right. thin oil will make its way thru tighter clearances......Thats why todays cars require 5 weight or even 0 weight. this is because higher visicoty oil will not lube the bearings in todays engines per manufacture specs. alot of forigen cars reqiure 0 weight oil. In all my cars and trucks I run castrol syntec 5-50 weight. It will lube the vital engine parts eeven when it is -20 and makes for easyer starting.. Plus thre oil will not break down in extream temps. inother words you get all the benifits of a "5 weight" oil when its cold and "50 weight" oil when the engine is under extream temps. best of both worlds. I would not run it in a car that has a oil leak as it is 6 bucks a quart.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
