Put a blade on the front. I have a heavy-duty loader on my M. I made a 42" high blade for it that mounts on the loader arms when the bucket is removed. If you put some small glide pieces behind the blade in the center and about a foot from each end, you won't dig up your drive. I have fluid in the rear tires, and two wheel weights on each side. I've never needed chains. If the tractor is on a level stretch of drive or road, I can move through an amazing amount of snow in 4th gear. Last year I added a back blade on the three point hitch. The added weight on the back made things work even better, and I can push snow back when I want to.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
