The two springs hold the impeller shaft forward so that it does not rub on the back side of the impeller. The water pump has two ball bearings that support the pulley but, unlike modern pumps, the impeller shaft is carried on a brass sleeve type bearing. That is why there are two grease zerks. On lubes the two ball bearings. The other lubes the impeller shaft bushing. If you over grease the bushing the excess is forced into the coolant. If you do not grease it, the coolant will get in between the shaft and bushing and cause corrosion and rapid wear. Missing or broken springs will also allow the coolant to replace the grease more quickly.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
